# Using Your Zwift Play
> Your Zwift Play allows you to level up your Zwift experience and gives you the freedom to control the UI and in-game functions. Check out the table below for...
Source: https://support.zwift.com/en_us/using-your-zwift-play-rkO3EZB3
Last updated: 2025-01-28T22:21:28.243Z
Check out the table below for an overview of the controllers and then find out more about what each button press will do for you depending on if you're [navigating the UI](#Navigating_the_UI) or [riding or working out in Zwift](#Riding_or_Working_Out_in_).
Your Zwift Play is equipped with haptic feedback, you can turn this off in your [in-game settings](https://support.zwift.com/in-game-settings-Hy_tSDDnt).
The first time you pair your Zwift Play controllers with Zwift, you'll see a Zwift Play tutorial. You can view this tutorial again—and an overview of your controllers—from the CONTROLS tab in the SETTINGS menu in-game.
![Overview](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Hardware/Resources/Images/Overview.png "Overview")
Description
Buttons
1
Left Controller Navigation Pad
![Left](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Hardware/Resources/Images/Left.png "Left") ![Up](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Hardware/Resources/Images/Up.png "Up") ![Right](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Hardware/Resources/Images/Right_35x33.png "Right") ![Down](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Hardware/Resources/Images/Down_32x32.png "Down")
2
Power Button
![Power](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Hardware/Resources/Images/Power Button1.png "Power")
3
Right Controller Action Buttons
![](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Hardware/Resources/Images/A1_33x33.png "A") ![B](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Hardware/Resources/Images/B1.png "B") ![Y](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Hardware/Resources/Images/Y1_33x32.png "Y") ![Z](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Hardware/Resources/Images/Z1_31x31.png "Z")
4
USB Port
N/A
5
Handlebar Strap
N/A
6
Analog Paddle
![ZL](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Hardware/Resources/Images/ZL.png "ZL") ![ZR](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Hardware/Resources/Images/ZR.png "ZR")
7
Side Button
![LS](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Hardware/Resources/Images/LS.png "LS") ![RS](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Hardware/Resources/Images/RS.png "RS")
## Navigating the UI
You can use the following buttons when navigating the UI including the Home Screen and your in-game settings.
Button
Function
![A](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Hardware/Resources/Images/A.png "A")
Press to select.
![B](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Hardware/Resources/Images/B.png "B")
Press to go back.
Open prompt to exit the game when on the Home Screen.
You may need to press Esc twice to open the prompt.
Press to navigate left.
Press to navigate up.
Press to navigate right.
Press to navigate down.
## Riding or Working Out in Zwift
Check out the table below for info on what your Zwift Play can do while you're riding, working out, or participating in an event.
Button
Function
Press to select.
Press to go back.
Press to display the menu when in a ride or workout.
![Y](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Hardware/Resources/Images/Y.png "Y")
Press to use a Power Up when riding.
Press and hold to skip a block in a workout.
![Z](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Hardware/Resources/Images/Z.png "Z")
Press to return a Ride On.
Press and hold to give a ride on to 5 riders within your vicinity.
Press to navigate the action bar.
Press to cycle the Mini Map view when riding.
Press to go left at an intersection when riding.
Press to display or hide the action bar.
Press to go straight at an intersection.
![Right](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Hardware/Resources/Images/Right.png "Right")
Press to go right at an intersection.
Press and hold to make a U-turn while free riding or in a workout.
Press to display the look back camera in a Zwift Event.
Press to [shift](https://support.zwift.com/en_us/zwift-ride-shift-style-and-gear-range-rksYezzIC) down while riding.
Press to decrease intensity in a workout.
You'll need to have ERG turned on, and you'll need to be riding at your target wattage to control workout intensity from the side buttons.
Press to [shift](https://support.zwift.com/en_us/zwift-ride-shift-style-and-gear-range-rksYezzIC) up while riding.
Press to increase intensity in a workout.
Push right to brake.
You can adjust and turn off braking sensitivity in your [in-game settings](https://support.zwift.com/in-game-settings-for-cycling-Hy_tSDDnt).
Braking isn't available during workouts.
Push left to steer left.
Push left to brake.
Push right to steer right.
## Tech Specs
*   Bluetooth 5
*   USB-C charge port
*   Haptic Feedback
*   Rechargable Li-Ion battery
*   Zwift Play experience enabled by TGO technology.
Ride On.
\-The Team at Zwift
