# Supported Devices to Run Zwift
> As we continue to develop more immersive and feature-rich elements within Zwift, we strongly recommend a device that falls into our Optimal options below...
Source: https://support.zwift.com/en_us/supported-devices-to-run-zwift-H1Cj9QbeB
Last updated: 2026-10-30T16:10:47.035Z
This article outlines device requirements for running Zwift. For Zwift Companion app requirements, see [Supported Devices to Run the Zwift Companion App](https://support.zwift.com/en_us/supported-devices-to-run-the-zwift-companion-app-HkxP5byIc).
Zwift Video has additional storage and internet requirements. If you're using Zwift Video, your device must meet the requirements in this article and the additional [Zwift Video Requirements](https://support.zwift.com/zwift-video-requirements-r1dLt0x6ze).
## Computers
Zwift runs on a range of computer setups. For the best experience, use a device that meets the Optimal specifications. Devices that meet Minimum specs can still run Zwift but may have reduced performance.
Graphics performance depends heavily on the GPU (graphics processor)—lower-end GPUs may impact visual quality and frame rate.
Component
Minimum
Optimal
Operating System (OS)
**Windows:** Microsoft® Windows 10 (64-bit) or higher
**macOS:** macOS® 10.14.4
**Windows:** Current version of Microsoft® Windows (64-bit)
**macOS:** Current version of macOS®
CPU
**Windows:** Intel® Core™ i3 or AMD Athlon™ (x86-64 only; ARM not supported)
**macOS:** Intel-based Mac (64-bit)
**Windows:** Intel® Core™ i7 or AMD Ryzen™ (x86-64 only; ARM not supported)
**macOS:** Apple silicon (M-series) or Intel Core i7
Installed RAM
8 GB
16 GB
GPU
1 GB dedicated GPU, or embedded Intel® HD 4000 or AMD R5
2 GB Radeon™ R9 290 series, or NVIDIA® GeForce™ GTX 970
Storage
HDD with 5 GB free space
SSD with 5 GB of free space
Bluetooth
Version 4.0 or greater
### Notes
*   macOS beta versions are not supported.
*   Windows PCs with ARM-based processors (64-bit ARM architecture), including Qualcomm Snapdragon devices, are not supported.
*   Touchscreen input is not supported on Windows.
*   Windows N or KN editions require the [Media Feature Pack](https://support.microsoft.com/en-us/topic/media-feature-pack-list-for-windows-n-editions-c1c6fffa-d052-8338-7a79-a4bb980a700a) for full functionality.
*   Limited system permissions (for example, restricted folder access) may impact performance.
## Smartphones, Tablets, and Apple TV®
Use the table below to check supported devices and requirements for running Zwift on mobile devices and Apple TV.
Minimum supported versions for iOS and tvOS will be updated to iOS 15 and tvOS 15 August 4, 2026.
Device
Supported Devices
Requirements
Notes
Android®
*   Android devices
*   Android® 9.0 or higher
*   Arm64-v8a ABI (Arm64 architecture)
*   3 GB of RAM or more
*   4 GB free storage space
*   OpenGL ES 3.0 or higher
*   Bluetooth version 4.0 or higher
If the Zwift app does not appear in the Google Play Store on your device, the device is not compatible.
On Android devices that support multiple user profiles, Zwift must be installed and opened from the primary user profile.
iPhone®
*   iPhone® SE or newer
*   iPhone®6S or newer
*   iOS® 15.0 or higher
*   At least 4 GB of free storage space
iOS beta versions are not supported.
iPad®
*   iPad mini® 4 or newer
*   iPad® Air 2 or newer
*   iPad® Pro or newer
*   iPad® 5th generation or newer
Apple TV®
*   Apple TV 4K (1st generation or newer)
*   Apple TV HD (4th generation)
*   tvOS 15 or higher
See [Apple's website](https://support.apple.com/en-us/HT200008 "Apple's website") to identify your Apple TV model.
### Notes
*   External keyboards are not supported on smartphones, tablets, and Apple TV.
Ride On.
\-The Team at Zwift
