# Setting Up Your Zwift Ride Smart Frame
> After setting up your compatible trainer, follow these steps to add your Zwift Ride Smart Frame...
Source: https://support.zwift.com/en_us/setting-up-your-zwift-ride-smart-frame-B1nkgMG8A
Last updated: 2026-09-09T12:59:59.804Z
For set up videos, see [Zwift Ride Setup](https://uk.zwift.com/pages/zwift-ride-setup).
## Confirming Trainer Setup
Before mounting your Zwift Ride Smart Frame, make sure you have enough space for your trainer, Zwift Ride Smart Frame, device, and room to get on and off the frame comfortably.
The minimum space needed for your Zwift Ride depends on your setup.
*   **Zwift Ride with KICKR CORE 2:** 48" (120 cm) x 60" (150 cm)
If you're using another compatible trainer, the space needed may be different. Make sure you have enough room for your complete setup and to get on and off your Zwift Ride comfortably.
Confirm the following:
1.  Your location has:
    *   A strong wireless network signal.
    *   Access to a wall outlet for the trainer and charging the handlebar controllers.
    *   Good ventilation.
    *   Optional: A fan to cool your room and a training mat to protect your floor.
2.  Your trainer is on a flat, level surface, is seated firmly, and doesn't move.
3.  A Zwift Cog is installed on your trainer and the sprocket is set to number 1.
    Show image
    ![Zwift Cog with sprocket position highlighted](https://content-cdn.zwift.com/support/EN/Hardware/Resources/Images/Cog Sprocket Position.png "Sprocket Set to 1")
    Do not mount your Zwift Ride Smart Frame on a trainer with a cassette.
4.  The necessary thru axle adapters are installed on your trainer.
    *   The drive-side thru axle adapter.
    *   The non-drive-side thru axle adapter.
    If your trainer has quick release adapters installed, remove them and install thru axle adapters.
    Show image
    ![Trainer Adapter Locations](https://content-cdn.zwift.com/support/EN/Hardware/Resources/Images/Trainer Adapters.png "Trainer Adapter Locations")
5.  Your trainer's firmware is up-to-date.
    You may need to download the trainer manufacturer's app from the [Google Play Store](https://play.google.com/store/apps?utm_source=na_Med&utm_medium=hasem&utm_content=Nov0520&utm_campaign=Evergreen&pcampaignid=MKT-EDR-na-us-1707532-Med-hasem-ap-Evergreen-Nov0520-Text_Search_BKWS-id_100470_%7CEXA%7CONSEM_kwid_43700023142507457_adgroupid_44836427956_keywordid_kwd-294868089100&gad_source=1&gclid=CjwKCAjwuMC2BhA7EiwAmJKRrG0f3b0o4Y_bWs29SodKFf5islldI1MUuuWXlP1O7ue5iiKeJjCR1xoCZvsQAvD_BwE&gclsrc=aw.ds) or the [iOS App Store](https://www.apple.com/app-store/) to update the firmware.
## Installing a Riser Foot
If your trainer requires one of the included riser feet, install it now. See [Zwift Ride Smart Frame Trainer Compatibility](https://support.zwift.com/zwift-ride-smart-frame-trainer-compatibility-ByuZ01ps0) to check whether your trainer requires a riser foot.
If you bought Zwift Ride with KICKR CORE 2, skip to [Mounting Your Zwift Ride Smart Frame on the Trainer](#Mounting_Your_Zwift_Ride_on_the_Trainer). Zwift Ride riser feet aren't included or required with the Wahoo KICKR CORE 2.
To install a riser foot:
1.  Open the Zwift Ride Smart Frame boxes and remove all items.
2.  Carefully lay your Zwift Ride Smart Frame on its side.
3.  Using your frame key, unscrew both bolts from the bottom of the front foot.
    Show image
    ![Riser Foot Bolts](https://content-cdn.zwift.com/support/EN/Hardware/Resources/Images/Riser Foot Screws.png "Riser Foot Bolts")
4.  Remove the bolts and foot from the Zwift Ride Smart Frame.
    *   If you're installing the small riser foot, keep the bolts and washers. You'll need them to install the small riser foot.
5.  Insert the appropriate-size riser foot for your trainer.
    *   If you're installing the small riser foot, reinstall the bolts and washers you removed from the original foot.
6.  Using your frame key, tighten the bolts.
## Mounting Your Zwift Ride Smart Frame on the Trainer
1.  If you haven't already, open the Zwift Ride Smart Frame boxes and remove all items.
2.  Position the rear dropouts of the Zwift Ride Smart Frame onto the adapters.
3.  Insert the thru axle from the drive side through the Zwift Cog on the trainer.
4.  Use the frame key to tighten the thru axle.
    Show image
    ![Install and Tighten Thru Axle](https://content-cdn.zwift.com/support/EN/Hardware/Resources/Images/Installing Thru Axle.png "Install and Tighten Thru Axle")
5.  Place the chain on the Zwift Cog.
    1.  Pull the chain tensioner—the orange circle—down to loosen the chain.
    2.  Move the chain over and set it on the Zwift Cog.
    3.  Pull the chain tensioner back up to re-tension the chain.
        Show image
        ![Lift Up Chain Tensioner](https://content-cdn.zwift.com/support/EN/Hardware/Resources/Images/Reposition Chain Tensioner.png "Lift Up Chain Tensioner")
## Assembling Your Zwift Ride Smart Frame
Once the Zwift Ride Smart Frame is mounted on the trainer, assemble the rest of the frame.
1.  Install the handlebar stem:
    1.  Insert the handlebar stem into the front leg with the tray facing forward.
        You may need to loosen the bolt on the front of the front leg to insert the handlebar stem.
    2.  Using the bike fit recommendation card included with your Zwift Ride, set the handlebar stem to the appropriate letter for your height.
    3.  Once the handlebar stem is in position, use the frame key to tighten the bolt on the front of the front leg.
        *   If you have a torque wrench, tighten the adjustment bolt to 10Nm.
        Show image
        ![Tighten Handlebar Stem in Place](https://content-cdn.zwift.com/support/EN/Hardware/Resources/Images/Tighten Handlebar Stem.png "Tighten Handlebar Stem in Place")
2.  Install the handlebar controllers:
    1.  Using the frame key, unscrew the bolt from the bottom of the cap at the end of the handlebar stem and remove the cap.
    2.  Position the handlebar controllers with the orange paddles facing forward.
        Show image
        ![Install Handlebar Controllers](https://content-cdn.zwift.com/support/EN/Hardware/Resources/Images/Install Handlebar Controllers.png "Install Handlebar Controllers")
    3.  Lift the tray and slot the handlebar controllers into the track under the tray.
        You may need to loosen the bolt on the bottom of the handlebar controllers to allow it to slide into the track.
    4.  Using the bike fit recommendation card, set the handlebar to the appropriate letter for your height.
    5.  Once the handlebar controller is in position, use the frame key to tighten the bolt on the top of the handlebar controller.
        Show image
        ![Tighten Handlebar](https://content-cdn.zwift.com/support/EN/Hardware/Resources/Images/Tighten Handlebar.png "Tighten Handlebar")
3.  Reinstall the cap, or install your tablet holder instead:
    1.  Insert the cap or tablet holder into the end of the handlebar stem.
        Show image
        ![Install Cap/Tablet Holder](https://content-cdn.zwift.com/support/EN/Hardware/Resources/Images/Install Cap-Tablet Holder.png "Install Cap/Tablet Holder")
    2.  Reinsert the bolt through the bottom of the cap or tablet holder and tighten it using the frame key.
    3.  Place the phone tray mat, or the tablet tray mat, over the adjustment point for your handlebar controller.
        Show image
        ![Install Tray Mat](https://content-cdn.zwift.com/support/EN/Hardware/Resources/Images/Install Tray Mat.png "Install Tray Mat")
4.  Install the pedals.
    If your Zwift Ride has adjustable cranks and you're unsure which crank position to use, we recommend using the 170mm position.
    1.  Match the pedal labeled **R** with the right crank, labeled **R**.
    2.  Hand screw the pedal into the crank until it's secure—follow the direction shown on the crank.
    3.  Using your frame key, tighten the pedal from the other side, following the direction shown on the crank.
    4.  Match the pedal labeled **L** with the left crank, labeled **L**.
    5.  Hand screw the pedal into the crank until it's secure, following the direction shown on the crank.
    6.  Using your frame key, tighten the pedal from the other side, following the direction shown on the crank.
        Show image
        ![Install Pedals](https://content-cdn.zwift.com/support/EN/Hardware/Resources/Images/Install Pedals.png "Install Pedals")
5.  Place the two cable tidies on the front leg to secure the handlebar controller cable.
    Show image
    ![Install Cable Tidies](https://content-cdn.zwift.com/support/EN/Hardware/Resources/Images/Install Cable Tidies.png "Install Cable Tidies")
6.  Using the bike fit recommendation card, set the saddle to the appropriate letter for your height.
7.  Sit on the saddle and check your bike fit. If needed, make further adjustments.
8.  When you're happy with the adjustments, store your frame key in the dock on the frame.
    Show image
    ![Store Frame Key](https://content-cdn.zwift.com/support/EN/Hardware/Resources/Images/Store Frame Key.png "Store Frame Key")
## Related Articles
*   [Zwift Ride Smart Frame Trainer Compatibility](https://support.zwift.com/zwift-ride-smart-frame-trainer-compatibility-ByuZ01ps0)
*   [Wahoo KICKR CORE Zwift One and KICKR CORE 2 Set Up and Troubleshooting](https://support.zwift.com/en_us/wahoo-kickr-core-zwift-one-and-kickr-core-2-set-up-and-troubleshooting-BkY_Cvq6)
*   [Zwift Ride Torque Values](https://support.zwift.com/en_us/zwift-ride-torque-values-S15XvDyuGe)
*   [Supported Devices to Run Zwift](https://support.zwift.com/supported-devices-to-run-zwift-H1Cj9QbeB)
*   [Installing a Zwift Cog With Freehub](https://support.zwift.com/en_us/installing-a-zwift-cog-with-freehub-S1EqREQa)
*   [Adjusting Your Zwift Cog Sprocket](https://support.zwift.com/en_us/adjusting-your-zwift-cog-sprocket-BJxSF4VrZe)
*   [Adjusting Your Zwift Ride](https://support.zwift.com/en_us/adjusting-your-zwift-ride-SyUBRM8A)
*   [Installing New Pedals on Your Zwift Ride](https://support.zwift.com/en_us/installing-new-pedals-on-your-zwift-ride-ryCRZGUC)
Ride On.
\-The Team at Zwift
