# Registering for a Running Event
> Whether it's a group run or a race Zwift mass-start events give you a chance to experience the rush of running in a peloton—from the comfort of home...
Source: https://support.zwift.com/en_us/registering-for-a-running-event-ByEke6o2Y
Last updated: 2025-05-29T22:33:30.098Z
# Registering For a Running Event
Whether it's a group run or a race, Zwift mass-start events give you a chance to experience the rush of running in a peloton—from the comfort of home. If you need to change sub group or drop out of an event, check out the steps in the [sub group](#Changing) section below. When registering for an event, keep in mind that many of them will have different subgroups based on speed:
Group
Distance
Completion Time
A
Half Marathon
Under 1:35
5k
Under 21 min
B
Half Marathon
1:35-1:50
5k
21-25 min
C
Half Marathon
1:50 - 2:20
5k
25-30 min
D
Half Marathon
More than 2:20
5k
More than 30 min
E
\*Walk/run events designed for runners of all abilities. (Running speeds will vary and there are several walking breaks throughout the event).
You can register for an event [in-game](#In-Game), on the [Zwift Companion app](#Joining), or through [zwift.com](#zwift.co). If you need to change sub group or drop out of an event, check out the steps in the [sub group](#Changing) section below.
Check out our article for info on [event sub groups and event rules](https://support.zwift.com/en_us/event-sub-groups-and-event-rules-S16xjbsXs).
## In-Game
If an event or group run is scheduled to occur in the next hour, you can register directly in-game by following these steps:
1.  Launch Zwift and if necessary, sign in.
2.  When the Home Screen loads, do one of the following:
    *   Select **EVENTS**.
    *   Select an event from the **EVENTS** carousel.
    *   Scroll through the **EVENTS** carousel and select the **Events** tile.
![Select Events from the Home Screen](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Running/Resources/Images/1.64 Running - Events with Carousel.png "Select Events")
1.  Once you find the event, select the ![Orange Plus](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Running/Resources/Images/Advanced Features/plus_52x46.jpg "Plus Icon") icon next to the subgroup you want to join.
If you want to RSVP further in advance, you can do so from the [Zwift Companion app](#Joining).
Some events have only one group, or are designated as an open E group indicating it's intended for runners of any level.
## Zwift Companion App
Registering for an event via the Zwift Companion (ZC) app is just as simple as registering on your computer—but also comes with the benefit of allowing you to RSVP further in advance.
If you're already running in-game, you can't register for an event from the ZC app-you need to save and exit/discard your run, then register for the event.
1.  Access the **EVENTS**page by completing one of the following:
    *   If you're using an Android device, select the ![Zwift Companion app menu button](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Running/Resources/Images/ZC_Menu_Button.png "Menu Button") icon then select **Events**.
    *   If you're using an iOS device, select **EVENTS** in the bottom navigation bar.
2.  To toggle between event types, select one of the following:
    *   To view cycling events, select ![White cycle in dark grey background](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Running/Resources/Images/Advanced Features/bike_60x46.jpg "Cycle").
    *   To view running events, select ![Zwifter running on dark grey background](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Running/Resources/Images/Advanced Features/Run1.JPG "Run").
    *   To join or create a [meetup](https://support.zwift.com/en_us/creating-a-cycling-meetup-with-zwift-companion-HJP7iUd4r), select ![Meetup group outlines on a dark grey background button](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Running/Resources/Images/Advanced Features/meetup_41x32.jpg "Meetup").
3.  Scroll up and down to view all available events.
4.  To filter the type of events you see, select **FILTERS**.
![Select FILTERS](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Running/Resources/Images/ZC Event Filters.png "Select FILTERS")
1.  Once you've selected the options you want to include or remove from your results—select **APPLY FILTERS**.
![Select Filters](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Running/Resources/Images/ZC Event Filters Running.png "Select Filters")
1.  If you want to join the event, select the event and then select the ![Orange Plus](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Running/Resources/Images/Advanced Features/plus_52x46.jpg "Plus Icon") icon for the subgroup you want to join.
2.  You can select to set a reminder in ZC for 15 minutes, 30 minutes, or 60 minutes before the event starts.
3.  You can select to set a calendar reminder for 15 minutes, 30 minutes, or 60 minutes before the event starts.
4.  Once you select your preferences, select **SAVE**.
![Reminder Settings](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Running/Resources/Images/ZC Reminder Settings.png "Reminder Settings")
1.  If this is your first time setting a reminder with ZC, select **OK** to give ZC access to your calendar.
    You'll see a notification appear on the event banner showing the event you're planning on attending.
## zwift.com/events
Registering for an event on [zwift.com/events](http://zwift.com/events) is nearly identical to joining through the Companion app—and like registering through the app—it also lets you RSVP further in advance. Here's how:
If you're already running in game, you cannot register for an event from the website - you need to save and exit or discard your run , register for the event, and then sign in again.
1.  From [zwift.com](https://zwift.com/ "zwift.com") navigate to the events page—or just go to [Zwift.com/events](https://zwift.com/events/ "Zwift.com/Events").
2.  Search or browse through upcoming events for the one you're interested in and select the event listing.
    Inside the event's submenu you'll see a description of the event, its average speed, the number of laps, time, and route.
3.  From the event listing, select the ![Orange Plus](https://zwiftdmz-marcom-us-east.s3.us-east-1.amazonaws.com/support/EN/Running/Resources/Images/Advanced Features/plus_52x46.jpg "Plus Icon") icon next to the event subgroup you want to join.
## Changing Sub Group or Leaving an Event
If you accidentally signed up for an event, picked the wrong sub group, or are unable to attend, complete the steps below:
1.  Navigate to the event you want to update.
2.  If you want to run in a different category, select the category you want to register for.
3.  If you want to leave the event, select the category you're signed up for to remove the check mark.
See you on the road.
\-The Team at Zwift
