# Manually Adjusting Your FTP
> You can manually adjust your FTP in Zwift or on the web. FTP stands for Functional Threshold Power and represents the highest power output, measured in watts...
Source: https://support.zwift.com/en_us/manually-adjusting-your-ftp-S1bUyp38v
Last updated: 2026-09-28T17:11:02.067Z
FTP stands for Functional Threshold Power and represents the highest power output, measured in watts, you can expect to average over a long period of time—usually around an hour. Zwift uses your FTP to determine the difficulty of your workouts. The higher your FTP, the higher the wattage targets you'll see during an interval.
We recommend completing an FTP test to identify an accurate FTP before starting your workouts.
## Adjust Your FTP in Zwift
1.  From the **Home Screen**, select your initials, then select **My profile**.
    Show image
    ![Home screen showing my profile option](https://content-cdn.zwift.com/support/EN/Cycling/Resources/Images/Cycling - Home Screen My Profile 1.122.png "Select My Profile")
2.  Enter the value you'd like to use in the **FTP** field, then select **SAVE**.
    Show image
    ![Enter your FTP](https://content-cdn.zwift.com/support/EN/Cycling/Resources/Images/1.51 Cycling Public Profile - FTP.png "Enter Your FTP")
## Adjust Your FTP on the Web
1.  Go to [zwift.com/settings/profile](http://www.zwift.com/settings/profile) and sign in.
2.  Enter the value you'd like to use in the FTP field, then select **SAVE CHANGES**.
    Show image
    ![Zwift.com profile with FTP field highlighted](https://content-cdn.zwift.com/support/EN/Cycling/Resources/Images/Profile - FTP -26.png "Enter Your FTP")
## Things to Know
*   You can adjust your workout intensity during a workout if your FTP feels too high or too low.
## Related Articles
*   [FTP Test](https://support.zwift.com/en_us/ftp-test-HypJnI_NH)
*   [Adjusting Your Workout Intensity](https://support.zwift.com/en_us/adjusting-your-workout-intensity-B1PftWd1g)
*   [Workout Mode for Cycling](https://support.zwift.com/en_us/workout-mode-for-cycling-HkhS0S0F)
*   [Workouts and FTP FAQ](https://support.zwift.com/en_us/workouts-and-ftp-faq-HyJXHL_v1x)
*   [Connecting Your Devices for Cycling](https://support.zwift.com/en_us/connecting-your-devices-for-cycling-HJIFDrw5S)
Ride On.
\-The Team at Zwift
