# In-Game Settings for Cycling
> You can adjust a range of in-game settings in Zwift. These settings are available from the Home Screen or during a ride, and changes sync across your...
Source: https://support.zwift.com/en_us/in-game-settings-for-cycling-Hy_tSDDnt
Last updated: 2026-11-03T22:54:36.962Z
You can adjust a range of in-game settings in Zwift. These settings are available from the Home Screen or during a ride, and changes sync across your devices. Follow the steps below to update your settings or review the sections to learn what each setting does.
*   [Preferences](#Preferences)
*   [Audio & Video](#Audio)
*   [HUD](#HUD)
*   [Hardware](#Hardware)
*   [Permissions](#Permissions)
## Adjusting Your In-Game Settings
1.  Open Settings:
    *   From the Home Screen, select your initials, then select **My settings**.
        Show image
        ![Home screen showing my settings option](https://content-cdn.zwift.com/support/EN/Cycling/Resources/Images/Cycling - Home Screen My Settings 1.122.png "Select My Settings")
    *   During a ride, select **Menu**, then **Settings**.
        Show image
        ![Menu button shown in an activity](https://content-cdn.zwift.com/support/EN/Cycling/Resources/Images/Cycling - MENU 1.74.png "Select MENU")
2.  Select a category:
    *   **Preferences:** General gameplay and experience settings.
    *   **Audio & Video:** Sound, display, and visual effects settings.
    *   **HUD:**  Customize what metrics and information appear on screen.
    *   **Hardware:** Configure trainers, controllers, and input behavior.
    *   **Controls:** View connected devices (Zwift Ride, Zwift Play, Zwift Click) and access controller tutorials.
    *   **Permissions:** Manage data consent settings.
    *   **About:** To view your game version and build number.
3.  Select **OK** to save your changes and continue.
    Show image
    ![Setting options](https://content-cdn.zwift.com/support/EN/Cycling/Resources/Images/Cycling - Home Screen My Settings Settings 1.122.png "Settings")
## Preferences
Setting
Description
Preferred Language
Set your preferred language.
Leaderboards
Leaderboards appear on the left side of your HUD unless Ride Stats or Splits are selected in the same display area. When riding a segment, the leaderboard shows rankings for that segment. Toggle between Always and Auto.
Measurements
Display measurements in Imperial or Metric units.
Screenshot Uploading
Control whether screenshots are saved in Zwift and shared to any linked third-party platforms (if connected). Choose Always, Only My Shots, or Never.
Show Group-Chat
Show or hide messages from nearby Zwifters in the group chat.
Laptop Battery Saver
Adjust battery usage with Max, Med, or Min Battery Saver.
Video Screenshots
Enable or disable video capture. This feature may not be available on all devices.
Language Filter
Turn profanity filtering in chat On or Off.
Workout Pain Effect
Simulates fatigue effects on screen as effort increases. This setting only appears during a workout.
Rider Highlighting
Highlight your avatar and select nearby riders in a pack.
Route HoloReplay
Show a HoloReplay of your personal best, most recent effort, or both for a route. Available when you have a recorded effort for that route. You can also turn this feature off.
Segment HoloReplay
Show a HoloReplay of your personal best, most recent effort, or both for timed segments. Available when you have a recorded segment effort. You can also turn this feature off.
Leaderboard HoloReplay
Show other Zwifters’ HoloReplays on routes with leaderboards.
HoloReplay Privacy
Set your HoloReplay visibility to Public or Private.
## Audio & Video
Setting
Description
Title Music
Turn the background music On or Off.
Game Sound Volume
Adjust menu and notification sound volume.
3D World Volume
Adjust environmental and riding sound volume.
Streak Flair
Show or hide your Streak Flair.
Screen Shake Effect
Turn the screen shake effect On or Off.
Game Resolution
Adjust in-game resolution.
Screen Mode
Choose Full Screen or Windowed mode.
## HUD
Setting
Description
Left Display Slot 1 - 4
Choose which metric to display in each left-side HUD slot. Available metrics may vary depending on your connected devices. Options include:
*   Cadence (RPM)
*   Average Power (AVG)
*   Heart Rate (BPM)
*   Energy Burned (CAL)
*   Power to Weight (W/KG)
*   Kilojoules (KJ)
*   Stress Points (SP)
*   Core Temperature (DEG)
*   Heat Strain Index (HSI)
*   Weighted Power (WP)
*   Power Balance (L/R)
*   Average W/KG
*   Average Speed
*   Split Average Power
*   Split Average Heart Rate
*   Split Average Cadence
Ride Stats Slot 1 - 2
Choose which metrics appear in Ride Stats. Available metrics may vary depending on your connected devices. Options include:
*   Cadence (RPM)
*   Heart Rate (BPM)
*   Kilojoules (KJ)
*   Average W/KG
*   Average Speed
Elevation Display Sensitivity
Control when the Dynamic Elevation Display appears.
## Hardware
Setting
Description
Trainer Difficulty
Adjust how strongly in-game gradients affect resistance. Only available when a controllable trainer is connected.
Power Estimation Mode
Select how estimated power is calculated for supported trainers (Classic or zPower).
Power Display
Choose how your power output is displayed—smoothed (3-second average) or real-time.
Tire Size
Select the value that matches the size printed on your rear tire.
Braking Sensitivity
Adjust braking response or turn it off. Only available when Zwift Play or Zwift Ride is paired.
Controller Haptic
Enable or disable controller vibration for Zwift Play or Zwift Ride.
Tacx Neo Road Feel
Turn Road Feel On or Off when using a Tacx Neo trainer.
Road Feel is available during free rides, but you won't feel road textures during ERG workouts or when Watt Lock is enabled.
Intersection Controls
Enable or disable steering-based route selection at intersections when using a supported steering device.
Virtual Shifting
Enable or disable virtual shifting for Zwift Click or Zwift Play.
Shift Style
Configure button behavior for virtual shifting with Zwift Ride or Zwift Click.
Gear Range
Adjust the number and range of virtual gears for Zwift Ride.
Drop Buttons
Customize the function of the lower buttons on Zwift Ride handlebars.
## Permissions
Setting
Description
Heart Rate Data Consent
Give or withdraw consent to use heart rate data in Zwift.
## Related Articles
*   [Virtual Shifting FAQ](https://support.zwift.com/en_us/virtual-shifting-faq-r16UiRFlT)
*   [Shift Style and Gear Range](https://support.zwift.com/en_us/shift-style-and-gear-range-rksYezzIC)
*   [HoloReplay FAQ](https://support.zwift.com/en_us/shift-style-and-gear-range-rksYezzIC)
*   [Using the Heads Up Display when Cycling](https://support.zwift.com/en_us/using-the-heads-up-display-when-cycling-rJepA4beS)
*   [Taking Screenshots and Capturing Video in Zwift](https://support.zwift.com/en_us/taking-screenshots-and-capturing-video-in-zwift-HJylsU_4H)
*   [Tire Size Conversion Chart](https://support.zwift.com/tire-size-conversion-chart-HyH6NiQckg)
*   [Connecting Your Devices for Cycling](https://support.zwift.com/en_us/connecting-your-devices-for-cycling-HJIFDrw5S)
*   [ERG Mode in Workouts](https://support.zwift.com/erg-mode-in-workouts-SkQJC8OEH)
*   [Watt Lock](https://support.zwift.com/en_us/watt-lock-ry231aIhzg)
Ride On.
\-The Team at Zwift
