# Connecting Your Heart Rate Monitor Using the Zwift Hub
> You can use your Zwift Hub as a Bluetooth bridge to connect your heart rate monitor (HRM) to Zwift. First, connect your HRM to the Zwift Hub in the Zwift...
Source: https://support.zwift.com/en_us/connecting-your-heart-rate-monitor-using-the-zwift-hub-BJdmU8so
Last updated: 2026-09-23T22:30:57.775Z
First, connect your HRM to the Zwift Hub in the Zwift Companion (ZC) app, then finish setup in Zwift.
## Before You Start
*   Download the app from the [App Store](https://itunes.apple.com/us/app/zwift-mobile-link/id934083691?mt=8 "App Store") or [Google Play](https://play.google.com/store/apps/details?id=com.zwift.android.prod "Google Play").
*   Turn on Bluetooth on your mobile device.
*   You may need to enable Location Services to connect devices when using ZC.
*   On iOS, you may need to allow Bluetooth access for the ZC app in your device settings.
*   Make sure your Zwift Hub is powered on and the LED is flashing blue.
## Connecting Your Heart Rate Monitor in ZC
1.  Open the ZC app and sign in.
2.  Open the menu.
    *   Android™: Select the menu icon.
    *   iOS®: Select **MORE**.
3.  Select **EQUIPMENT**.
4.  Select your Zwift Hub.
5.  Select **PAIR DEVICE**.
6.  Select your heart rate monitor from the list.
7.  Once you've connected your HRM in ZC, open Zwift and finish setup from the Paired Devices screen. See [Connecting a Heart Rate Monitor](https://support.zwift.com/connecting-a-heart-rate-monitor-Hk0MimWlS) for steps to connect your device and provide heart rate data consent.
## Connecting Your Heart Rate Monitor in Zwift
After you've connected your HRM to the Zwift Hub in the Zwift Companion app, connect it in Zwift.
For steps to connect your HRM and provide heart rate data consent, see [Connecting a Heart Rate Monitor](https://support.zwift.com/connecting-a-heart-rate-monitor-Hk0MimWlS).
## Things to Know
*   If you've enabled background pairing and Zwift remembers your Zwift Hub and heart rate monitor from your previous session, Zwift can connect them in the background when you start Zwift.
*   You can turn background pairing on or off from PAIRING OPTIONS on the PAIRED DEVICES screen.
*   Make sure you're wearing your heart rate monitor and it's turned on so the ZC app can find it.
*   Make sure your HRM isn’t connected to another app or device, or Zwift may not detect it.
*   You can't connect a smartwatch to the Zwift Hub as a heart rate monitor. If you want to use your smartwatch as a heart rate monitor, you'll need to connect it directly with Zwift.
*   When you finish connecting your HRM in Zwift, you’ll be asked to provide consent to use your heart rate data.
*   You can withdraw your consent at any time from your in-game settings: My Settings > Permissions > Heart Rate Data Consent.
*   When connected, an HRM lets you view your heart rate in-game and includes that data in your activity.
*   To connect your HRM to another device, first unplug your Zwift Hub.
## Related Articles
*   [Connecting Your Devices for Cycling](https://support.zwift.com/en_us/connecting-your-devices-for-cycling-HJIFDrw5S)
*   [Connecting a Heart Rate Monitor](https://support.zwift.com/en_us/connecting-a-heart-rate-monitor-Hk0MimWlS)
*   [Updating Your Zwift Hub Firmware](https://support.zwift.com/updating-your-zwift-hub-firmware-ByJG2Y9Jj)
*   [Using the Zwift Companion App](https://support.zwift.com/using-the-zwift-companion-app-rJ7ayD_ES)
Ride On.
\-The Team at Zwift
